Old 30th April 2009, 11:52 PM
zrblue zrblue is offline
erm, well kind of, if you want an age related number plate then you have to prove that your car was built with a certain amount of parts sourced from one donor car & having the vin plates helps you prove thats what you have done, along with lots of photos of your build & photos of you stripping the donor etc, you won,t get to use the same reg number of the donor but will get the same year affix that the donor had, ie... G reg sierra = G reg Roadster.
It seems like an awful lot of hassle to get an age related plate...is there some benefit to be had by having an age related plate over a Q plate?
