Old 1st May 2009, 09:01 PM
SeriesLandy's Avatar
John;
Just a comment if I may? Sod it I will anyway!
I made a mistake in assembling the pedal box and welding it all up before I offered up the master cylinder and only then realized i had to enlarge the hole to something like 29 mm.
The fact I had all the pedal brackets welded in place was a major pain when it can to holding the box on my mill and drilling the large hole.
It is only a suggestion that people specify the hole size to suit their master cylinder and for a few extra £'s you drill that for them, then weld it all up.
Just a thought.
Adrian
I had to do the same, however I hadn't welded up before.
I tacked a bit of angle iron over the hole so I could centre the arbour for the holesaw then filled the original mounting holes with weld.
At the time I thought it was just me so didn't comment.
