  #18
Old 27th May 2009, 09:00 PM
I can see no reason from an engineering point of view why the pedalbox must be removal, but chassis plate CP16 is a structural part of the chassis to prevent twisting and also acts as a heat sheild to the engine compartment. I am sure if you made this as one fixed plate all will be ok. Nut it will need to be fully seam / stitch welded.
