Old 18th August 2009, 10:32 AM
geeman's Avatar
geeman geeman is offline
ok, i just had a look at adrianh's pics of the maniforld and what he has done looks pretty good, but i just thought why not just use some flexible exhaust pipe to go to the side, and then use stainless on all the bits that will be visiable fromt he outside. sounds like ti would be easier than making several bends, and shouldnt be too hard?
my build pics
Old 18th August 2009, 10:46 AM
i too had the same idea but when discussing this with "Mark" the other day, he did bring up a good point..... would the flexible type bend to that degree?
i already have the silencer & so just need to connect the manifold to the silencer, how have others done this? any pics?
Old 18th August 2009, 05:41 PM
The flexi stuff is a bit of a pain to weld as it's thin guage metal,bends are available locally to you Andy in Boro, pm for number.
Old 18th August 2009, 05:54 PM
geeman's Avatar
im glad ive got a tig that goes down to 20 amps, so welding thin stuff aint a problem, im just wondering, do you know how flexible it actually is, as in would it be easy to do a 90+degree bend in.
my build pics
Old 18th August 2009, 07:56 PM
mark mark is offline
I could be wrong geeman the flexi pipes that i have personally seen would not be capable of bending 90degrees+
It probably would be possible with a long piece of flexi but there isnt a lot of room in the engine bay on the exhaust side for that!
personally im going to buy a few bends etc and fabricate my own
Old 18th August 2009, 08:37 PM
TSM Locost's Avatar
Default Exhaust alternatives.
Westfield 1600 cvh also fit 1800 cvh, usually 1 or 2 on ebay.
check out some xr3i xr2i tubular ones as well. I shortened the 2 pipes from the manifold and used 2 bends to bring out the side. cant find any pic's
Be Lucky, Mike.
Old 18th August 2009, 10:11 PM
I go with Mark on this one,it is possible to get a 90 deg bend but given the diameter of the pipe the radius will be large.
And by thin metal I mean thin.
45/90 deg bends in tube are available from most exhaust suppliers just look on the Bosal website and you will get an idea of what I mean and I think this will be the easyiest answer.
Good Luck.
