Old 30th August 2009, 03:08 PM
Longerr Longerr is offline
Default Total weight of the car
I was weighting our car during this weekend and it turned out it has 700kg (1540lbs). It was quite a surprise for me because I was counting that it will be around 500kg (1100lbs). What is your weight of the car?
Old 30th August 2009, 06:12 PM
squbti's Avatar
squbti squbti is offline
how do you weigh a car?
Old 30th August 2009, 06:19 PM
Weighbridge.....Metal scrapyard.
Old 30th August 2009, 07:38 PM
squbti's Avatar
i meant is there a way one can weigh a car in the workshop ? maybe with a forklift ?
Old 30th August 2009, 08:19 PM
4 Sets of cheap bathroom scales
Assuming they each go to about 30 stone, should be good for about 760kg
They will also give you a good general idea of your individual corner weights
Old 30th August 2009, 08:27 PM
Indeed they will, if the floor is level or you level up each corner first. I know Bonzo knows this, but I thought I would mention it for the benefit of others.
Vinyl floor tiles are good for the levelling, nice and cheap, consistent thickness and they don't compress.
Last edited by mr henderson : 30th August 2009 at 08:28 PM. Reason: Because I'm such a nice person
Old 31st August 2009, 08:32 AM
Anyone else who knows his weight of the car
Old 31st August 2009, 09:07 AM
Neil P Neil P is offline
Mine through SVA at 512kg with a Toyota 4AGE engine.
Personally, I think that says more about the accuracy of their weighing than the featherweight build I created!
Neil
Old 31st August 2009, 12:10 PM
hm that is a very good weight, we have made it exactly according to the book with 2 mm chassis tubes and the weight is almost 200kg more, we used M42B BMW engine 1.8L but I doubt that this is the reason...
http://picasaweb.google.com/Longerr8...49659940976338
Old 31st August 2009, 06:01 PM
squbti's Avatar
4 sets of bathroom scales ? my wife will think i´ve lost the plot .i think i´ll wait for the sva,i´m using 1.5mm chassis tubes so it should be good.
