Old 1st September 2009, 05:18 PM
geeman's Avatar
geeman geeman is offline
While were on the subject of wheels, i found a set of 15 in alloys near me for aout £150, but the seller has only told me thay have come off a peugeot 106 so it has a bigger bore(65.1mm) and a offset of 20mm(i think) which im not sure if would be suitable?
if not, i have found many other alloys mostly which are 17in ones. I know that for optimum geometory, 15 in alloys are required, but would i encounter any problems using bigger wheels?
Thanks.
my build pics
Old 1st September 2009, 06:03 PM
I am putting 16s on mine. I got a set for the right price, and I need them to fit my brakes behind
Sean
Old 2nd September 2009, 09:01 PM
Peugeot/Citroen have the same PCD as Ford on the Sierra with four studs,I am lead to believe that the later wheels on the Focus etc are different.
Old 2nd September 2009, 10:06 PM
andyp andyp is offline
just to add a bit peugeot/citroen have the same pcd but have an et15 off set . this would mean they would stick out a bit further
Old 2nd September 2009, 10:24 PM
Depends how much later you mean. I have Focus ST170 brake discs and they are 4x108 (and 300mm diameter) (ST170 02-04 years)
Sean
Old 2nd September 2009, 11:32 PM
les g les g is offline
Sean
FFS....
gosh .......i thought ours where overkill at 260mm vented
that will be some real stoppiing power in a roadster
hope your harness,s dont have a crutch strap!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
cheers les g
Old 3rd September 2009, 08:58 AM
Originally Posted by les g View Post
FFS....
cheers les g
They were the right price - and big brakes are fun
They are bloody heavy though, I might look into getting the 2 piece type, with the alloy inner bell.
If they turn out to be a bit much then I may swap to smaller ones, but I also like the look of big brakes
Sean
