![]() I already know about that one
![]() I wrote it in the book when the question was answered before the forum got hacked. Shall we leave it as a surprise? Sean |
![]() yeah ok Sean,
tho i,ll admit i must,ve read the book page for page about 4 times before i found it ![]() ![]() andy |
![]() You guys
![]() I sold the CBR! It is being picked up on Wednesday, which meens I finally have a budget £360, it may be small but it should get me some steel and a saw. Right CP24 ![]()
Sent from my iPad, from who knows where in the world I was building but I am not now! ![]() Build Pictures Build Thread |
![]() Save yourself £100 and just buy a hacksaw, it barely takes any time to cut the steel to a good degree of accuracy. If you dont get along with the hacksaw then think about buying a saw
1.8 Silvertop Zetec (ZX6R Carbs + Megajolt) + Type 9 My Build Blog: http://www.haynes.co.uk/forums/showthread.php?t=2736 - Last Update: 31st October 2020 Total Spent so far: Stopped counting ![]() |
![]() I must admit.
![]() I got well cobbed off constantly changing the angle on my bandsaw ![]() ![]() I ended up using the good ole hacksaw on my angle cuts, I found it quicker than faffing about with the angle adjustment on the bandsaw. Buy a decent hacksaw & most importantly good quality blades. Sandvic, Bahco or the likes ![]()
![]() I find when cutting an angle with a hacksaw it will allways 'run off' which tends to infuriate me, plus the one with the most toys at the end wins!
Looking at getting the steel next Friday.
![]() Quote:
Then cut though the 4 faces separately. I find that helps when cutting angles Sean |
![]() Scribe the cut line with a sharp scriber, cut a fraction long & then fettle to your lines with a 60 or 80 grit flap disk in the grinder.
![]() A flapdisk will whip the excess material in seconds & will leave a nicely prepared surface. ![]() EDIT Common reasons for run off/out when cutting with a hacksaw Not having the work piece level in the vice, I use a small level to ensure that it is. Too much force, let the blade do the cutting Standing in the wrong position when cutting, stand in a straight line to the angle that you want to cut. not enough tension on the blade Poor quality hacksaw or blade Pesonally, I find it helfull to lower the heel of the saw when cutting ERW square tube. It helps to cut downwards whilst still making forward progress. This way you can adjust both cutting directions as you go & before you run off line
I am not a complete idiot...........Some of the parts are missing !! Ronnie ![]() www.roadster-builders.co.uk Last edited by Bonzo : 26th September 2009 at 09:44 PM. Reason: More text |
![]() Quote:
![]() let us know if you find out where CP24 goes ![]() good luck with your build & don,t forget to enjoy it ![]() cheers andy |
