Old 28th December 2009, 12:16 PM
happyjo happyjo is offline
Question Sierra 1.6 GL P reg
CAn someone answer the following questions.
I have managed to track down a 1.6 ford sierra GL P reg.
Does anybody know if that would be okay for the Roadster, I assume it will but will it give enough power for track days.?
Does it come with EFI?
Thank you
Old 28th December 2009, 12:22 PM
GL? They stoped that trim in 89
P reg? The last know cars are on an M plate.
1.6 Could be
Pinto Carbed
CVH Carbed
CVH CFi ( single point carb )
Old 28th December 2009, 12:24 PM
Ps.. track days are not all about power, a 1600 is not exactly blessed in the HP department but should still be fun.
Old 28th December 2009, 12:40 PM
Question
I am going to look at the car in the new year, might be a GLS.
If all goes to plan I should get it for near to nothing and still has the keys and paperwork.
Is it worth holding out for the 2.0
Thank you Happyjo
Old 28th December 2009, 01:21 PM
GLS was only 2.0 and 2.9
GLX was a 1.6 trim from 91-93
Old 28th December 2009, 04:13 PM
1.6 will be fine to start with. most people rip the pintos out after they are through iva.
Old 29th December 2009, 03:11 PM
Thumbs up
Thanks guys, I am thinking about fuel economy/ insurance etc.
Another assumption, if i fit the 1.6 then it has the same gearbox and engine mounts so transplanting the bigger enegine should be quite easy later.
Old 29th December 2009, 04:31 PM
the 1.6 will be a pinto and it's type 9 box will fit most other 4pot fords althought the 1.6 is not as strong as the 2.0 BOX.
How many miles do you expect to do a year? MPG is uualy not worth thinking about unless you plan to do a lot of touring.
Old 29th December 2009, 04:52 PM
Smile
I know this sounds a bit far off, i have not even bought the steel yet.
But I would love to drive down to the south of france on a touring holiday just before i retire.
another 12 years to go so should just have enough time to build then.
The london to brighton sounds great to.
Cheers for your reply
Happyjo
