Old 9th February 2010, 09:55 PM
Enoch Enoch is offline
You have that the wrong way round Baz - the resistance of the bulb is the constant, it's the voltage that's the variable. As voltage increases and the resistance stays the same the current increases. Therefore higher engine speeds = higher voltage = higher current. always allow for this in calculating wire ratings. In the aircraft industry we used to do that, add 50 per cent then double it
Old 9th February 2010, 10:10 PM
Well, that's close to multiplying by pi, which is used when estimating software development ;-D
Old 9th February 2010, 10:48 PM
i worked out the rating then doubled it on everything.
Old 11th February 2010, 05:56 PM
doh i know. i was just thinking in the wrong wavelength again
its the night shifts you know
Old 11th February 2010, 06:18 PM
here's a quick calc linkey so no thinking is required
http://www.sengpielaudio.com/calculator-ohm.htm
55w bulb = 2.61 ohm at 12v
11.5v=4.41A
12v=4.58A
14v=5.34A
