Old 15th February 2010, 09:05 PM
Davey's Avatar
Davey Davey is offline
Default 5 1/2 J X13 alloy wheels for sale
Hi there, if anyone is interested I have a set of five 5 1/2J X13" alloy rims for sale, I think they're early Capri jobbies, four stud (damn just realised I didn't check the PCD of the stud holes, will check them tomorrow if anyone is interested. Anyway here's a poor phot of them, I'll get a better shot tomorrow. I'd like to think a set of five would be worth a nice round Ton, anybody interested? Ignore the tyres as although there is plenty of tread on them they're all ancient and none will hold air pressure for long.
D.
Old 15th February 2010, 09:21 PM
RAYLEE29's Avatar
RAYLEE29 RAYLEE29 is offline
Personally id say a ton was rather optomistic
theyre mk2 capri ghia wheels
and practically worthless but good luck
Ray
Total spend so far £1116.08
1ST ALBUM HERE
2ND ALBUM HERE
Old 15th February 2010, 09:39 PM
Davey's Avatar
Thanks for the input Ray.
D.
Old 15th February 2010, 11:27 PM
you need minimum of 15's for the roadster so you have a bit of a limited market on her although someone might want them of a different car. may be worth putting them up on locost builders as there are always people looking for a cheep set of 13's for track days
Old 15th February 2010, 11:39 PM
Why a minimum of 15's???
Old 15th February 2010, 11:53 PM
Big Vern Big Vern is offline
The haynes roadster was designed around 15" wheels with I think 195/50x15 suggested as the tyre size. So the handling is likely to be best suited to these size tyres. The wheel arches are also designed for these wheels though so long as your rolling diameter is the same as for 195/50x15 then I can see no problem with the wheel arches. ie you could use lower profile 16" or 14" with greater profile - though the handling wont be as sharp as the slip angle increases with increase in profile.
Best bet for those wheels would be to find a Capri or Escort website.
Friend of mine had a set like that on her 3.0S Capri.
BV.
Old 16th February 2010, 07:24 PM
frankie boy's Avatar
HI
You need 15” wheels to clear the rear upright. The bolts on the bottom wish bone run very close to the inner wheel rim.
my Roadster
