![]() If you get a pre 94 engine then you don't need a cat, and you are held to a much lower emissions standard (i've got myself a pre 94 1.8 silvertop zetec). If you are looking to buy a brand new zetec, then you can buy a pre 94 engine such as a CVH, get the car to pass the IVA with that engine and then swap it out for a brand new zetec.
1.8 Silvertop Zetec (ZX6R Carbs + Megajolt) + Type 9 My Build Blog: http://www.haynes.co.uk/forums/showthread.php?t=2736 - Last Update: 31st October 2020 Total Spent so far: Stopped counting ![]() |
![]() I dont have the money for a brand new engine :P And not really enough to buy 2 engines either lol.
If needs be i'd put the zetec through iva on injection with a cat, but if possible, i'd prefer to get it to pass on carbs. ![]() |
![]() Just buy yourself a pre 94 zetec engine, I got mine for £40, then buy some bike carbs and a megajolt system. The 1.8 zetec will run quite happily on ZX9R carbs and megajolt without proper tuning on a rolling road and will sail through the IVA.
![]() That would be the best soloution, if i could find a pre 94 zetec! Does the IVA man require proof of age/car
![]() The only proof he requires is the engine number as he then uses that to look up the manufacture date of the engine to decide if it is a pre 94 engine.
EDIT: Looks like im slightly wrong with this. You need the engine number and some proof of the engines age. Depending on the testing station it could be just a print out of the burton power website which tells you what year the engine was made from the engine number, or you might need a letter from ford themselves telling you when your engine was made.
1.8 Silvertop Zetec (ZX6R Carbs + Megajolt) + Type 9 My Build Blog: http://www.haynes.co.uk/forums/showthread.php?t=2736 - Last Update: 31st October 2020 Total Spent so far: Stopped counting ![]() Last edited by Tatey : 14th May 2010 at 10:40 PM. |
