Old 26th July 2010, 06:18 PM
David_17's Avatar
David_17 David_17 is offline
I was planning on using some steel tube with a nut welded inside on the end as an extension bar, so that the indicator will bolt to the tube (assuming yours have threads), then some how fix the steel tube to the front frame of the chassis in a similar way.
Something like this...
I've got some tube if you need some (came with my chassis kit for the rear alu tub, so won't be needing much of it). If you want a bit, give me a shout.
*updated 7/6/11*
