![]() Surely you would want the steering column in the centre of the drivers side of the car.(middle of TR 9 section on drivers side)
![]() yep, as above, the transmission tunnel is different both sides, so the center of the chassis wouldn't work.
The center measurement of the drivers footwell/steering mount can be worked out looking at cp16 (or cp17 I think) it is in the back of the book.
~ My Build Diary - http://davesroadster.blogspot.com/ *updated 7/6/11* Best bit so far: Getting it running Worst bit so far: Cutting steel for wishbones and engine mounts. Most annoying bit so far: Generator packing up half way through welding. |
![]() According to my cad model it is 290mm from the centerline of the chassis to the steering column centerline.
Cheers Dave
![]() Great thanks guys. Will have another look in the morning with fresh eyes, sure that will help.
