Old 12th August 2010, 07:47 AM
To be honest I'm not sure if it's a trade name or not, all I know is that some polycarb. does not bend and tends to shatter when you bend it in a V die on a brake press.
Old 12th August 2010, 07:57 AM
Davey's Avatar
Davey Davey is offline
Lexan is a trade name as far as I'm aware but it is not just ordinary polycarbonate, its damned near indestructible which is why its used in bus stops etc. I was once asked to try and destroy a piece to demonstrate its toughness, it withstood 15 minutes of battering with a four pound lump hammer. it was badly deformed but didn't break.
D.
Old 12th August 2010, 08:52 AM
RAYLEE29's Avatar
RAYLEE29 RAYLEE29 is offline
Makrolon is made from polycarbonate we used to use it for power press guards its immensely strong and can be bent too.
if you need to bend 180 degrees you prob need to talk to a plastic specialist
Ray
Total spend so far £1116.08
1ST ALBUM HERE
2ND ALBUM HERE
Old 13th August 2010, 04:34 PM
tex tex is offline
lexan is pretty tough stuff - i bought some 4mm smoked for the top part of my custom made doors on the dax - looked pretty cool. bare ally on the bottom
Old 13th August 2010, 07:25 PM
trickydicky0_16 trickydicky0_16 is offline
lexan is a trade name for polycarb,it can be bent on a press brake though you might need to over bend it if you want 90 degrees, it also can be punched on a punch press
tricky
Old 14th August 2010, 12:13 PM
As Ray say's Makrolon is the dogs bits,the right grade is bullet proof the piece I tried took a .357 magnum and just dented it.
