Old 12th September 2010, 08:58 PM
Originally Posted by gaz05 View Post
Anyone know if I need the gearbox sandwich plate
Hi Mate,
If you mean the thin dust cover thingy...then yes, keep hold of it
Also keep the gearbox mount, the big bit with rivets holding it together that also has a thick rubber insert inside the housing, you,ll be able to use it for the Roadster, once you.ve cut away the big housing part of it.
