Old 5th October 2010, 09:18 PM
Twin's Avatar
Twin Twin is offline
Default Mig help!
Hi guys,
need a bit of help, as you can see from the pic I need the bit that joins these 2.
not sure what its called or where I'd get it from, any advice would be cool
cheers.
Twin
CSF £857.19
Twins Roadster
Old 5th October 2010, 09:26 PM
Spring is missing from inner part of torch where threaded part is close to the rubber,you also need a tip for the wrie to come out,copper coloured.
Hope this makes some sense.
Old 5th October 2010, 09:32 PM
If it's the hobby torch I'm thinking of it's all there just you have the wrong shroud. The chrome part should screw straight on to the brass swan neck. There should be cork type insulator inside the shroud with a copper or brass fiting with the same thread as the swan neck. You also need the correct size tips for the wire to come through. The complete set up looks like the pic in the ebay listing.
http://cgi.ebay.co.uk/HOBBY-MIG-WELD...em230633 2d58
or
http://cgi.ebay.co.uk/Hobby-Mig-Torc...em230a8a 092b
Old 5th October 2010, 09:51 PM
Twin's Avatar
I have the tip, just never put it in the pic
Twin
CSF £857.19
Twins Roadster
machine mart for a tip and shroud ( if it is the wrong one )
