Old 16th October 2010, 07:22 PM
Funny you should mention the transmission tunnel width, was looking at mine earlier & thought that there was a bit of scope for a slimmer tunnel
Old 16th October 2010, 07:30 PM
les g les g is offline
Talking
i agree oh wise one
what about a tapered tunnel
narrower at the top than the bottom
i nearly bought an Aries chassis once but the fit was a bit tight
the guy did say he could move the offside top tunnel rail to the left to accomodate me
thats another option i reckon just moving the drivers side
of the tunnel
unlikely to have two hippo,s in little car at the same time
cheers les g
Old 16th October 2010, 07:37 PM
Could be wrong but I think the shafts are two different lengths so it should be possible to move the diff over making the drivers side larger.
Old 16th October 2010, 07:40 PM
stunning idea just use two of the longest driveshafts
this forum is great for bouncing ideas around
cheers les g
Old 16th October 2010, 07:53 PM
Yes Les, tis surprising how things just spring to mind.
I guess it would not be impossible to have one seating position wider at the expense of the other
Stuck my seat in place the other day & really hate the handbrake position with a vengance
Smack bang, right in line with my elbow, my own fault for being such a shorhouse
No prizes for guessing what my next wee mod will be !!??
Old 16th October 2010, 08:52 PM
We made a chassis for an R1 install with a hand brake that was recessed into the tunnel when it was down, could'nt get it to disappear completly but certainly made a difference.
Old 16th October 2010, 08:59 PM
Thank's for that Phil
I picked up a slightly more compact lever from a Rover 25 the other day, thanks to some advice from Coozer ( Cheer's Steve )
Yes. I will remove the exisitng mounts & recess the lever into the tunnel a little .... I think it should work out fine
Ooooh, the Rover lever has a nice Chrome button too
Old 16th October 2010, 08:54 PM
Chris Gibbs's Avatar
Chris Gibbs Chris Gibbs is offline
The problem with using a driveshaft on the "wrong" side is that the shafts have a left hand thread on one side and a right hand thread on the other. The shaft on the wrong side would be trying to undo it's self.
Have you tried a standard width car?
I'm not going to be winning any "Mr Thin" titles myself, and I've never had a problem.
Chris
Old 17th October 2010, 02:33 PM
David_17's Avatar
David_17 David_17 is offline
Never thought about that when i put my driveshafts in - i just put the first one i picked up, thinking they were the same
Are they marked, which is which?
*updated 7/6/11*
