Old 1st February 2011, 05:27 PM
Wgroove Wgroove is offline
Originally Posted by Spikehaus View Post
Looks like that one has been answered, my prop was a heavy duty version so it cost a bit more, about £120 delivered, it was sent overnight courier!
For info it was:
700 mm L x 50.8 mm Dia Propshaft, 35 mm dia x 25 Teeth Sleeve, 4 Bolt flange
I am sure they will help you out,
Daz,
Sorry we where not it, usually close up at 3.30 and been away for a few weekends, when its a nice day give me a shout and we will make sure we are in. Not long until we can get a picture of then side by side!
Thanks for the detailed info !
I believe that you using a T9 gearbox. Mine is a MT75, will that make any difference ? The original prop i got was a two piece shaft. Do i have to use a piece from the old one ? Does the new one comes also in two pieces ?
Regards,
Wim
