Old 30th March 2011, 10:48 PM
You have the height of the chassis from the bottom edge of the lower rails to the top of the upper rails = 355mm,
the top of the bonnet is 230mm above the upper rails at the scuttle end & if my memory doesn,t fail me 171mm above the upper rails at the nose cone
so you have 585mm from base rail to top of bonnet at scuttle end
526mm from the base rail to top of bonnet at the nose cone end .
depends which bonnet you fit, as the new Saturn bonnet gives greater clearance in its larger bonnet bulge.
hope that helps.
Old 30th March 2011, 10:57 PM
tkpm tkpm is offline
Thanks for the measurements Andy
Have 300mm to spare in lengh and about a 1m in width and still have a decent work area, just need to clear out 14 years worth of junk from my old business.
Terry
Old 30th March 2011, 11:03 PM
no probs Terry , glad the info helped
Ahhh I remember the garage clearout
I,m building my car at my mothers home, as a family of 7 we moved in 40 yrs ago.....i,m sure you can imagine how much junk was in there
Its a good sized garage, got my Roadster in & still has about 10ft of work space in front of it. Only junk in there now is MYYYYY junk
Old 30th March 2011, 11:11 PM
Angry Junk?
JUNK? JUNK?
Thats not junk in my garage or yours its stuff waiting the time when I /you get around to using it!!
While I'm here whats the total volume of the space taken up by the book spec car ( at an ambient temp of 21C) on a thursday afternoon---please
Old 30th March 2011, 11:19 PM
Originally Posted by ayjay View Post
JUNK? JUNK?
I must confess, I,m a bit of a hoarder for things that I think "ah, maybe I,ll use this some day" sort of hoarder ,
Tho yes Ayjay, I do agree with you ...maybe I should have said "spare parts" instead of calling it junk
Hang on, I,ll have a go at the volume question , tho can,t remember last time we had 21c temp on a thursday
I,ll get my coat .
Old 30th March 2011, 11:30 PM
While I'm here whats the total volume of the space taken up by the book spec car --please
the approx volume of space taken up by a book spec Roadster with GRP bodywork is 3131.26....give or take a bit for not counting in the height of the roll bar
I really must get out more
Old 31st March 2011, 12:49 AM
Did you dunk it in a tank to see how much water it displaced?
Old 30th March 2011, 11:07 PM
CaptainCrash1971's Avatar
CaptainCrash1971 CaptainCrash1971 is offline
cheers Andy
knew I could rely on you. Looks like my temporary engine will fit without any alterations at all.
thanks again
Alan/Bob
Costs so far :- Too much but somehow not quite enough
http://alansroadster.blogspot.com/
Originally Posted by CaptainCrash1971 View Post
cheers Andy
thanks again
Alan/Bob
Sounds good
Tho may i say, take those measurements with a slight variance being possible due to the thickness of the GRP side panel return edge that sits on the upper chassis rails....tho its only approx 2 - 3 mm
Maybe I need to get out more glad the info helped.
