![]() Yes front to back, not easy to measure on your own though. If you take a measurement from the rearmost front bracket to one on the rear do exactly the same on the other side. If its on wheels measure centre of wheel to centre of wheel...it MUST be the same CASTOR MUST be the same angle also or weirdness will set in.
![]() Doesn't just apply to track cars it's a MUST for road use unless you like hedges
![]() I think I'm going to uses washers/ shims on the rear hubs to correct mine
![]() Puts me in mind of a Renault back in late 70s or early 80s .It was the Renault.5 Ithink. One of the rear wheels was about an inch forward of the other to accomodate some strange suspension idea. They made a selling point of it --Quirky/cute French "flair" or something like that( they were crap anyway ).
![]() Oooh 70s-80s Renault 5
The first thing that springs to mind is .... Rust ![]() ![]() Perhaps that was just Cornwall ![]()
![]() No I can assure you it wasn't just Cornwall. That wasn't the worst rust bucket Renault did either. Anyone out there old enough to remember the Renault Dauphin?
![]() Well it gets worse after measuring everything for several hours this evening it appears the wishbones and hubs introduce a little more error as stated by Talon and Trick earlier in this post as well so when there fitted I have the following errors
Front Track NS 0 Front Track OS +3mm Rear Track NS +3 Rear Track 0 Not realy sure the best way to resolve seems I would need a lot of shims but at least it will go around left hand bends well ![]() |
![]() Quote:
![]() i think i sweped one up in the workshop once for some reason my first boss had a thing for r4's and r5's the body roll was fantastic im sure you could get 30-35 deg then it would start to slide unrollable tho? |
