Old 4th May 2011, 04:36 PM
MarkB MarkB is offline
Originally Posted by AshG View Post
well speaking to tilly if i can remember correctly he reckons its the roll centre that is too high causing positive and negative camber changes on tight cornering.
Goes mad positive in mental mode but it does it both ends Ash that's why it's not so noticeable when you are bumbling along.
Old 4th May 2011, 04:39 PM
Tilly819 Tilly819 is offline
Originally Posted by MarkB View Post
Goes mad positive in mental mode.
AGREED
I seem to recall quite abit of scrub during suspension travel also IIRC
tilly
www.heraldic-motorsport.co.uk
Old 4th May 2011, 04:58 PM
Originally Posted by Tilly819 View Post
AGREED
tilly
Like I said best I wait for the boffin who knows the right words as I have my own words for stuff and will only confuse folk...but yeah you will be running off the rims when you push the car hard.
Old 4th May 2011, 08:35 PM
mark mark is offline
I'm aware that the front geometry is probably not perfect but it also sounds like some under-steer being provoked by your new big power and the extra weight
Teesside autodrome track has some very tight corners and my car did have the front outer wheel screeching as you describe when really pushing on, a few trial and error damper adjustments made the world of difference
I found once i had dialled out the front wheel screech that the lack of an lsd was more of an issue anyway in hairpin type corners
An lsd is next on my "want to do list" and probably a stronger upgraded type 9
I think its incredibly difficult to set these cars up to a certain spec and then be happy with them, there is so many variables from car to car and every corner you drive around, i know you can set the fundamental things within a reasonable margin but nothing beats driving round a track like your hair is on fire then making some adjustments and doing it again
Old 4th May 2011, 09:02 PM
its only 30kg heavier than it was with the pinto it didnt even make a difference to the ride height and the fact that tillys bike engined one does it too shows its not a weight issue.
really need to model it properly to work it all out been tinkering in solid works but it takes me ages to draw things as i don't use it all the time.
also there isnt any harm in redesigning the wishbones and makeing a new upright to see if it can be improved, nothing ventured nothing gained and all that.
My Pictures
Old 4th May 2011, 09:25 PM
les g les g is offline
Ash
please dont post a joke now
or you will end up banned
you know the rules
post jokes and be critical about the roadster and its.....
off to the naughty step for you......
lol
cheers les g
ps . i think your problem has been highlighted on here before
Old 4th May 2011, 09:37 PM
Have any here added a front and/or rear sway bar (anti-roll bar)? If so, what has been the effect on handling?
Old 4th May 2011, 10:15 PM
hopefully i can add to that data shortly as i have front and rear anti roll bars to fit.
Would be interested in what you guys com up with regarding the short falls of the sierra hub against a purpose made item.
Bought this book and it makes interesting reading.
http://cgi.ebay.co.uk/Build-and-Modi...item27b76cc814
