Old 12th May 2011, 01:12 PM
Enoch Enoch is offline
Don't know about the flywheel but I tapped in to my engine loom at the point where the 3 plugs were originally. I found that on my car there was an imobiliser wire that caught me out, I could not get a spark without sorting that out. You need a live going to your coil, your ignition amp and your ecu. The wiring for the fuel pump is a bit weird, it's a while back now but I seem to remember that it is switched negative from the ecu so the other side of the relay coil needs to be taken to a switched live. Do not take it to permanant live otherwise it does not work correctly Those were the only things that caught me out, hope that helps.
Eeeeeeeeeenoch.
Old 12th May 2011, 06:20 PM
shaun shaun is offline
Thanks for that Enoch, I have just fitted the flywheel from the Zetec, the bolt holes are the same. When you say ignition amp, is that the unit mounted under under the coil?
Shaun
http://www.shaunsroadster.wordpress.com
YOU CAN NEVER HAVE TOO MANY TOOLS!!!!
Old 12th May 2011, 06:54 PM
the pin outs of the plugs are on my website on an excell spreadsheet about fitting the 24V v6 in a sierra.
Old 12th May 2011, 07:26 PM
Cheers Twin, got your site saved as a favorite
Old 12th May 2011, 07:28 PM
you should be able to get it to run with very few wires connected to the plugs.
I should really do a write up..
Old 12th May 2011, 07:39 PM
rapidtornado's Avatar
That would be v.useful Mr TT for those of us that are not great at electrickity
Old 19th October 2011, 11:43 AM
Hi All,
Just been told by a Ford mechanic the zetec flywheel is too deep for the starter to engage. I have 3 questions: 1. is this true?
2. which flywheel will fit I have seen this on fleabay
http://www.ebay.co.uk/itm/NEW-FORD-P...item5d3072881a
would this fit.
3. i found out there is a 5" and a 3.5" pinto starter would anybody have one for sale or a part number?.
Thanks for all the help.
Shaun
