![]() Eg. if the tube you want is app 6" long and you need compound angle on each end. Cut two bits of tube app 4" long and slit one of the tubes down the middle and open it up so the other tube slides inside like a telescope. You can then fashion the angle one end offer it up to the flange, you can then angle the other end to suit and if slightly out rotate the two pieces and keep dressing the ends till right, you can also alter length to suit on the telescopic bit if you naff up.Tape them together when spot on and copy to a good bit.
![]() It's a simple thing to do if you have a point of reference on the tube and a vertical mill with a ripper cutter. Can you do a drawing for a machine shop to follow?
![]() Can do sketches but dont have a cad package or I could probably draw the tubes then print out
![]() Its a slower process, but I made a jig for my manifold to help. Clamped the flange in place and offered up the cut tubes. Tweaked them a little as compound angles are a swine. Had to redo a couple, marking the incorrect tubes to get a better cut next time. Then once I was happy fully welded it. Knowing perfectly the tubes were all in the correct place and angles were correct. I've attached a photo from when I did it.
![]() Just a little tip, using the same method as the last post, use a jig excatly as shown but to 'tweek' the tubes and get them to the right angle try using pipe lagging which can be cut and played with until you get the angles right then wrap a bit of paper around the lagging cut it flush with the end and then transfer the profile to your pukka tube
That's what I've done in the past Rapid ![]() |
![]() I plan to make mine with plasticlne/ play dough then wrapping with stiff paper and transferring to the tube to cut. One question though --does the tube need to be ROUND -Im thinking about using box section !
![]() er i would start buy cuting one tube over length and manual cutting it to suit starting with cyl 2+3 then making 1+4 as thay would be at more of an angle.
if your miging it a gap will not be a problem ![]() |
