Old 10th August 2011, 10:20 PM
Darryl Darryl is offline
I think I better wait til I have the body work before I weld anything on yet!
Guess I have a bit of saving to do!
Thanks guys,
Darryl
Old 11th August 2011, 05:31 PM
Originally Posted by Darryl View Post
Hi andy,
How high have you the rad sitting at? and how far out?
When i sit it so that the bottom outlet is inside the frame, its about 7 inches high?
also, what have you done about the third outlet on the rad as it only has 2 but as far as i no i need 3? i was thinkin of making an outlet using an old fan thermostat thats in the rad?
Many thanks for your help,
Darryl.
My Rad is about 2 to 3 inches forward of the front frame , at a slight angle which seems to more or less follow the lean back angle of the front frame, the top of the rad is also about 3 inches above the top of the front frame.
My Rad has the usual inlet / outlet points, a thermostat switch which i,ve blanked off ( i,m using an aftermarket fan/thermostat switch fitted elsewhere in the system) & also has a small overflow outlet at the top that i,ve connected to the expansion tank.
If you wish I could take a photo tomorrow if it would help ?
Old 11th August 2011, 08:31 PM
Andy, a photo would be great tanx if it wasn't too much bother!
Thanks very much,
Darryl
Old 11th August 2011, 11:52 PM
Thanks very much,
Darryl
no probs, i,ll post up a pic of the rad position tomorrow.
Old 14th August 2011, 08:50 PM
Thanks very much,
Darryl
Hi Darryl,
I,m having problems wth my photobucket to get a photo posted up for you, should be sorted by tomorrow evening so will post up then.
Old 15th August 2011, 11:16 PM
As promised, here,s a couple of pics of my POLO Rad fitted forward of the front frame.
Hope they help .
Old 15th August 2011, 11:54 PM
Hi andy,
Many thanks for the pics!
Clears things up alot!
Thanks again,
Darryl!
Old 15th August 2011, 11:58 PM
Hi andy,
Thanks again,
Darryl!
most welcome
glad the pics help, like the saying goes " a photo is worth a thousand words"
