Old 26th August 2011, 06:43 PM
mark mark is offline
Originally Posted by brainbug007 View Post
I decided to stick with the sierra bottle and managed to get a bracket made to hold it on. Is it considered ok to bolt the bottle to the bracket and then rivet the bracket to the chassis as wasn't there something around when you couldn't use rivets to attach things for iva?
Not true, use rivets for anything you want within reason!
Most people with an alloy floor will have used rivets to hold it on (myself included) so im sure they will mangage with your coolant tank just fine
Might be worth investing in a rivnut tool if you havnt already then you can bolt things on where required, you will use it plenty of times before your build is finished so worth the money
