Old 10th September 2011, 01:25 PM
Default quick rack cheapy
On ebay a cheap quick rack, seems good value.
http://www.ebay.co.uk/itm/Mk1-mk2-Es...item1e658390d7
Old 10th September 2011, 01:58 PM
Rally design do them for £86.90 delivered not much of a saving but it all counts.
Old 10th September 2011, 02:14 PM
Hi Bob
I get a little concerned when I see a steering rack described as Escort Mk1 / Mk2
The Mk1 rack has imperial threads meaning that the rack extensions will have to made to suit.
No big deal if you are making your own but a real problem if you have already bought the usual metric extensions
It looks very much as if the Rally Design 2.9 rack is a tad cheaper
http://www.rallydesign.co.uk/product...ducts_id=10557
At least with the Rally design rack you'll know it is definately a Mk2 Escort rack with metric rod ends.
Old 10th September 2011, 02:15 PM
Too quick for me Kev
Old 10th September 2011, 02:21 PM
Shame I'm not so with building this bluddy car.....keep getting side tracked wi other stuff
Old 10th September 2011, 02:25 PM
Know the feeling Kev
Got my lathe in pieces at the moment, what started as a simple motor change has turned into a major re-furb
Old 10th September 2011, 02:46 PM
Question
Hi Bob
Rally design it is then Ronnie, glad you pointed out the mk1/mk2 thing as that could have caused a problem x3.Who does the rack extensions?
Old 10th September 2011, 03:03 PM
Hi Bob
You can get the rack extensions from a number of places
Rally Design do them , Saturn do them, I think Tallon has them at times & Dave oxley on ebay quite often has them listed.
Some are alloy & others are mild steel so that's the first choice you have to make
You'll have to jog my memory on donor cars, Sierra or MX5 but be aware I am almost certain sure that the book length extensions are too long
I have a feeling that the book car used a shortened Escort rack & needed longer extensions ( Sure someone will confirm that for definate )
On my own Sierra based build I had to shorten the book spec extensions.
Rally Design & Saturn do the correct length alloy ones, I expect if Phil is doing a batch of mild steel ones, he will make sure that they are the correct length.
Hope that is of some help
