Old 31st January 2012, 07:37 PM
will_08 will_08 is offline
Originally Posted by mark View Post
I saw that on ebay, its about 2mins from my unit
Didnt bother bidding on it though as I have seen it geting abused on the industrial estate, someone attempting to drift...........badly!
The engine sounds like a bag of hammers too
Also if handyandy thinks its an easy fix he must have a magic wand as the whole car is twisted as its had a few prangs
Although I just could be winding you up
It is near my unit though, that bit was true
Good luck with getting it sorted, doesnt look like it will take much to put it right
Just the 1 word, Evil
Old 2nd February 2012, 05:57 PM
All the ones I have taken for VIC were tested and taxed on the same day.
Old 2nd February 2012, 07:23 PM
vmax1974's Avatar
vmax1974 vmax1974 is offline
You can get the car tested at the same time as a vic check but when I took a old car in they would not do the vic check cause the car failed the test something to be aware of although it was many moons ago now
Old 12th February 2012, 07:40 PM
Bag of hammers indeed.
The new shockers, wishbonses and swivels from MK are due to arrive with Andy on Tuesday.
Ive just made contact with the car's original builder scoobyis2cool who will be sending me copies of the build receipts, notes and photos from 2004. Though he hasn't been active on car forums for a while I was lucky to find he uses his old forum name on Ebay.
Old 5th April 2012, 11:42 AM
Well Andy's work got the Indy sailing through the MOT and Ive just been up to collect it from the sellers house in Stockton which gave a nice opportunity to meet up with Andy and Vmax over several cups of tea before heading back. Cant wait to get in VIC checked now and insured.
I knew the Indy was closely related to the Haynes but was surpised at how very similar they are both structuarlly and visually. The chassis is almost identical apart from the use of some curved tube in the transmission tunnel. The wishbones look different but fit the same, bodywork is slightly different
Old 5th April 2012, 12:41 PM
Both chassis where designed by the same guy that is why they are not too different in appearance, the Haynes body work is a cut and shut version of the Indy.
