Old 21st April 2012, 02:50 PM
well.. thats the ac an pas pumps ditched! much more room! things are starting to look good :-) Fitted my tyres at college yesterday and my oh my!
wowzers... did a mess in my trousers ;-)
on das front are a set of yoko advan neova which i won for 60!! bargain!!
and on dee back are a set of toyo proxies t1r's ;-) £30!!
and my friend did the spraying on my wheels which im very happy with!they are in a kind of grey metalic, looks real nice when the sun hits them!
thats the rad fitted this morning :-) now to do the drivers seat and other bits i have missed i reckon.
does the height on the rad look ok to you guys ?
Mike
Old 21st April 2012, 04:02 PM
nice work so far bud....the rad does look too high ...the rads position is determined by trial fitting the nosecone as the rad sits inside of it.
Old 21st April 2012, 05:50 PM
Default does this look ok?
hey all what do you all reckon to this
i will weld the rearward nut so that is locked and will lock it off with a nyloc nut, and obviously fully weld it all including the bolt to the plate.
and as for the rad it is far far far to high! so that will be coming down 3 inches or so!!
Old 29th April 2012, 08:12 PM
My M8 has 2 MK2 Astras with the CX25. He also has Tech 2 which helped him alot
Old 29th April 2012, 08:15 PM
Did he flash the user memory and do away with the imobilzer?
i was onabout seperating the bloomin thing from the loom haha
saying that.. I'd quite like to use the obd on my kit car, how did he get hold of the tech 2 software?
Old 13th May 2012, 02:40 PM
well , the strip down literally took an hour! then welded all remaining areas.. I still need to attach my seatbelt mounts but ill just take the primer off :-) It feels odd going back on yourself to progress forward!
still needs some areas painting and then a 2nd coat and then a black hammerite over coat!!
next on the list ...
weld in a steel section for my pedal box to sit on
propshaft (fit the uj)
brakes
fuel tank
and pump!
and track rod ends!
Old 10th June 2012, 12:28 PM
howdy doo all! well ive been pretty busy i guess ! measured all up to buy my ally! steering is all sorted and smooth as smooth can be ! :-)
done some more painting and secured my pedal box etc etc ...
me and my mongy face ;-)
Watch this space ! more progress to come quickly! hopfully!!
Old 21st April 2012, 06:37 PM
thanks for your kind words yeah , im going to be loweing it quite a bit and maybe put it on a slight slant. i was literally going by the rule of "aslong as its under the engine" haha but i spoke to andy and he said and liek youve said the bonnet has some depth on it
Old 22nd April 2012, 02:18 PM
привет!! had a laugh this morning! and yes I did make the brum noises and drifting screetches
And also photoshopped one of saturns pictures to the colour i would quite like (respects to ssc) :-)
Getting rather excited now that its taking shape!! :-D
Old 25th April 2012, 11:13 PM
howdy! 3 lil pics to keep us entertained :-D
got bored with that ended up ony slotting one :-P
so i did this instead ;-)
all in all very cool
