![]() So I tried to open the bonnet on my daily driver this afternoon to fill it up again with fluids and the release level under the steering wheel isn't working anymore
![]() Whats the car ? i had a Laguna that used to do that all the time could open it with a couple of long screwdrivers from underneath ..
![]() Its a MK1 Renault Scenic. Because the lever to open it still travels completely I'm guessing the cable has probly snapped somewhere? I can see the screwdriver method working, just need to work out where to put em I guess...
![]() Get someone to pull the lever while you thump the bonnet at the front. When it's open put some oil on the catch.
Total cost so far Materials £3,150 Tools £855 |
![]() Quote:
![]() I know most of aa/rac guys are twats
![]() ![]() Bob
![]() lol... managed to get it open by having the wife pull the lever and then me pulling up on the bonnet. Latch has rusted quite badly now so I've sprayed a load of oil on it which will hopefully sort it out longer term... Annoying though turns out when I put it in the garage to have the clutch done they've forgotten to put the dip stick back in the engine...
