Old 13th October 2012, 10:01 AM
Default Mirrors.. What Passes IVA..
So what mirriors are able to pass the IVA and require minimum fuss fitting.
Old 14th October 2012, 08:46 PM
I've seen a few cars that are fitted Honda CBR mirrors it's either an M8 or flat 2 bolt mounting plate so should be simple to make fit the scuttle.
http://i.ebayimg.com/t/PAIR-HONDA-CB...G)NUg~~_12.JPG
Old 14th October 2012, 09:24 PM
http://www.ebay.co.uk/itm/2211305505... 4.m1438.l2649
Is this them?
Old 15th October 2012, 10:11 AM
GSXR mirrors are another popular choice.
Old 15th October 2012, 11:56 PM
I took the el cheapo ones, well, they are el cheapo. I had to get M10x1.25 nuts to fasten them, the mirror surface is not ideally flat, and the articulating joint is not great (tends to spring back to the middle position). But they look kind of OK and the price is right.
http://www.ebay.co.uk/itm/PAIR-UNIVE...em4ab47 e9b8f
Old 20th October 2012, 10:06 PM
section 08 Indirect vision of iva manual is where you will find all the info needed
mostly radius, glass size and view angles
Old 21st October 2012, 11:30 AM
Is the scuttle stout enough to support that much mirror? It might wobble about a bit at speed even with a decent constipation plate behind. Just thoughts. What was the last word on the combo with the indicator in the end of it, is it ok for iva
B
Old 21st October 2012, 05:06 PM
Initially the mirrors were quite flimsy, but then I added ~70 mm diameter load spreading "washers" out of 2 mm ali on the inside, they helped a lot. These mirrors are not E-marked, but looks like that is not a requirement for IVA.
As for the side repeaters, I left them out for now. They must be mirror mounted or wing-mounted (and visible from the back) in order to pass the ECE requirements. Another silly idea I had are scuttle-mounted motorcycle stalks pointing upward.
