Old 10th November 2012, 03:08 PM
vmax1974's Avatar
vmax1974 vmax1974 is offline
Originally Posted by Numplumb View Post
Thanks will 08 for your reply I was thinking that they should be thicker, the build guide for them says 3mm though but I think I will use 5mm as you suggest
It only gives dimensions for the hole spacing I was thinking of using 150mm x 361mm x 5mm plates as I can't see any reason why they need to be exact width
The 361mm is the same as RS7 any thoughts?.
Mick.
I think I overlapped the seat back by a few mil just to be sure
