Old 10th February 2013, 07:05 PM
Hi all,
Well I've got going on the car again at last and decided to finish a few things off before starting new stuff.
1, Managed to finish installing my Aero catches at last, just needs fine tuning when I rebuild the car after mock up.
2, Nosecone bolted in place.
3, Steering column/brake pedal cover finished.
I redisgned my dashboard after some head scratching. I removed the the lower part of my dash where it meets the transmission tunnel and welded it to the underside cover panel instead. I've also moved it forward to give the dash a more broken up feel.
I also made an ally cover to go over my steering column bezel as there is a gap between the dash and the top plastic cover.
The ally panel which goes into the engine bay and under the scuttle will be a platform for me to mount most of my electical relays and ecu etc...
Brackets off of this will support the various electrical items I require to be hidden up.
Hopefully I will be able to remove the lower dash cover panel and scuttle to sort out any electrical problems that may arise without too much hassle.
The dash I'm going to pad with foam and cover in vinyl or leatherette. Other parts will be powder coated.
Next item on the list will be seat mounting and rear panel mounting.....
