a wee update. I needed to strip the rear uprights completely and I had a seized bolt stuck in one of them. I had cut the bolt to remove the upright from the wishbone.
I spent an age trying to get the damn circlip out of the upright and in the end took an old set of vice grips and welded them to the circlip! ![]() ![]() Came out in seconds and i pressed the bearings out with a 12 ton press. ![]() ![]() Ready for final blasting an painting.
1.6 Mazda B6 : Garrett TBO339 : 420cc WRX Injectors : FMIC : Microsquirt V3 : LC-2 Wideband : Toyota COP : 1.8 ATB LSD Build Started Jan 2013 : OTR Aug 2014 : Still OTR June 2024 |
Next up the seized bolt.
![]() I center drilled it on the mill and then used a dead center in the press to free it up and a long socket to push it through. ![]() ![]() ![]() It went with a bang.
I drifted it out the rest of the way.
![]() ![]() Another job done. Cheers Stot
Got the rear drivetrain bits blasted and painted. These are first coat pictures but I did the second coat this morning so they are done.
![]() ![]() ![]() I have new bearings, brake seals, ball joints etc to go on. Be rolling soon... Cheers Stot
Nice work!
I gave up trying to remove the bolts out of my rear uprights and bought another pair with them pre-removed ![]() |
![]() Cheers Stot
Nice work
Looking forward to seeing more! |
