![]() I used a Lazy riviter and it was easy work.
![]() I went 2mm steel floor and welded it all around in sections. It has a slight ripple but nothing too bad. Tbh i prefer to have the extra strength
![]() Thanks guys good advise
Phil with regards to the Front frame am I correct in saying you cut ff2 at 13 degrees then weld together once in the jig to keep the faces at 90 degrees
My build diary is at http://thailoz.wordpress.com/ |
![]() Yes the angles are 13' at the top of FF2 and FF3 with the outer sides 90' to the base of your jig. If you screw/weld two perfect 90' cubes to your jig then clamp FF2 + FF3 to them this will help later when you come to fit your top suspension brackets.
![]() thanks again I will give the a try
![]() You may also consider using sealed rivets as these don't let water into the box section
17.07.10 "Now i know the meaning of life" My Build pics http://www.flickr.com/photos/67605695@N04/ http://www.flickr.com/photos/97412063@N08/ |
