  #19
Old 13th August 2013, 07:33 PM
PorkChop PorkChop is offline
If Phil post was constructive about the possible failures of the Saturn chassis then that would be fine or peoples welding but it doesn't come across like that at all to me. Apparently he can't sleep at night thinking about it's short comings! A bit dramatic. No?
I read the not being able to sleep bit as either tongue in cheek, or he's like me. I sometimes go over what I need to do with this bit or that bit of the build.
We all know this and it's a good point so do destructive tests on your welds and make sure they're not going to let you down. That's what I did. There's no need to describe possible builders as "a less then proficient person" which is very polite insult to my mind considering the tone of his post.
I remember Albert posting up a youtube vid of someone showing you how to weld, where it was more like how NOT to weld. People may not be as thorough as you are with weld testing etc. And Phil did say 'may' not 'is'.
