			#21
			 Phil
	Is the book spec separation of sb4 enough to allow for the offset of the mx5 diff? As I have now placed my order for one of your diff covers I'm looking to crack on with the rear suspension framework and originally had the sb rails setup per Saturn design. About to revert back to book spec rear end now but just want to make sure I don't have to rework anything else. Cheers Mark  |
			#22
	nothing is impossible you just need to try harder!!! Build pictures http://s830.photobucket.com/user/brownster79/library/  |
			#23
			 SB4 on the drivers side needs moving by 5mm but you also need to take the input flange into account and the prop shaft, I'll send you a proper set of drawings and pictures once I have got both the 1600 and 1800 in place.
	Website http://www.talonmotorfabrication.co.uk/ Direct email phil@talonmotorfabrication.co.uk talonmotorfabrication@gmail.com Mobile office hours 07514098334  |
			#24
			 Great, thanks. I will leave my SB's tacked in place just now then and get the rear frame done.
	J.brownster: good to see someone else going down the 'new' route. Seen ur name on the wishbone list too which is also what I'm doing. Should save a fair bit of time! I'm off work this week so getting rear end done today then start stripping the donor next couple of days...good times! ![]()  |
			#25
			#26
 All the components for all the TMXR wishbones that are on order have been cut and profiled ready for assembly.
			#27
			 just like to say thanks to phil i received my engine mounts as promised and there excellent very happy customer
	any news on your roll cage yet im lucky enough to be off to jan the 6th now and really hoping to make some progress on the car this month  |
			#28
			 Phil,  what would be the damage for a set of plans?  I'm in West Oz, so a chassis premade isn't an option for me.
