Old 5th June 2014, 07:15 PM
Good luck for tomoz fella! Car looks great, with your running fault you say it does it when the car has warmed up!? Is the auto choke working correctly? If that isn't going right off it would run crap then check all your vacuum pipes are in the correct place. Hope you get it sorted before the test as I don't think he will be happy with the emissions if it's not running correctly.
Build pictures
