Old 7th September 2014, 10:46 AM
1.6 would be ~130kg, 1.8 ~165kg.
I put mine in whole but just used a heave chain as a load leveler. Looped the chain through the hoist eyes on the engine and over the engine crane hook then put an M12 bolt through the chain so that when lifted the engine was at the angle I wanted.
Took a couple of tries moving the bolt to different chain links but it was easy enough.
I just used the old seatbelt and tied a trusty granny knot in it. The length of the gearbox meant that I could easily move it to the correct angle
Old 7th September 2014, 10:57 AM
I used an old winch attached to a 2x6" beam in the garage and tied and gaffer taped a steal rope to the two lifting points on the engine. I just slide the rope one way or the other to adjust the position. A load leveller would of helped but I was being tight at the time.
I weighed the engine and gearbox on bathroom scales before putting it in. The Mazda 1.6 engine and gearbox with shortened loom, ecu, manifolds and oil but not gear oil weighed 177.7kg.
