Old 23rd November 2014, 08:41 PM
garyt garyt is offline
Hi , was really trying to avoid that if at all possible, mounting the s/c lower should reduce some of the heat transfer issues the mx5 conversion has, the airflow from the rad /fan will create some negative air pressure behind the I/c and I will fill the edges, so will see how that goes and if IF and only if, I will look at some sort of scoop duct directly for the I/c but at the moment don't really want to go the scoop route.
Cheers Gary
