Old 29th October 2009, 11:05 PM
davidimurray's Avatar
Hi Ash
I don't have one yet, although I have started drawing one up - it's a hideously complicated shape that doesn't seem to follow any standard dimensions so make take a while for me to get right! When do you need the profile for - before exeter?
Old 30th October 2009, 12:07 AM
i have hacked one out of 5mm plate for now but would like a nice pretty one. its the hole spacings that are the most critical. i sent some scans of my gasget to john at 3ge to see if he could draw them up but something went wrong with the file
Old 30th October 2009, 11:53 AM
3GE Components's Avatar
I've orderd a gasket from my local motor factors, so will have a pinto inlet flange to add to our list soon.
We currently have:-
Zetec
Duratec
C20XE Vauxhaul
as inlet flanges
Pinto
4AGE 20v Toyota
Audi 20v turbo's TO3/TO4
as exhaust flanges.
If anyone wants others please send me a gasket and I'll add them to our dxf list.
These flanges can be in alluminium upto 10mm thick, stainless upto 12mm thick and mild upto 20mm thick. Prices vary accordingly.
Kind regards
John
Old 30th October 2009, 01:05 PM
John
For your Pinto flanges what size are the inlet/exhaust hole? I was looking at getting mine cut to the same size as the port +1.5mm to allow for tube thickness. Are the exhaust ones cut to the square profile? Also do you include a hole for the water take off point on the head to the carbs. I'm not planning to use this so wouldn't want it on the flange.
Old 30th October 2009, 02:19 PM
Try Shortrack I think Jason does them.
Old 31st October 2009, 09:33 AM
Originally Posted by davidimurray View Post
John
Hi David,
Are you planning on puttnig the tubes inside the flange then? We can supply the hole sizes to suit this or to suit the tube welded on the plate. The exhausts are square in profile. We don't add the water take off point.
Kind regards
John
Old 31st October 2009, 09:24 PM
RAYLEE29's Avatar
RAYLEE29 RAYLEE29 is offline
Hi, the standard 2.0L inlets are 36.7mm dia if it helps, (I cut an inlet flange from 6mm plate last weekend).im fitting gsxr 600 carbs. Ray
Old 8th November 2009, 08:11 PM
squbti's Avatar
squbti squbti is offline
Is 8mm thick stainless steel plate enough for making the flanges?
