Old 24th March 2010, 08:33 PM
Originally Posted by dogwood View Post
So finaly given up on the bl**** injection stuff.
Refitted the Weber and 1800 wiring.
Had it firing up right off.
Main thing is, if it goes wrong at least I should be able to fix it.
If the injection stuff packs up I wouldn't even know where to start.
Going to be in the same boat as you mate .... I am starting with the modern injection route .... Gonna be B*****d if it goes wrong at a later date
Could write all I know about injection systems on the back of a stamp
I assume the shape of the inlet ports on the injection head are all about air flow .... Being as you are using carb, I doubt there will be quite so much demand for such a smooth air flow.
You may find that the carb is a little under jetted for the extra 200cc though .... Guess you won't know the full efect until you give it a test drive mate
Old 24th March 2010, 08:44 PM
dave when you come back bring the injection stuff and i will learn you how to do it
if you cant be bothered then im sure i can get you a session down ATSPEED on their rolling road to set the carb up proper so it dont go bang.
failing that i could always sort you a megajolt and bike carbs.
Old 24th March 2010, 08:45 PM
Now there's an offer he can't refuse
Old 24th March 2010, 08:55 PM
EFi is simple.
I hate Carbs. That why I have fitted a Polo GT 1.3 Injection engine to our MK1 golf. I could not get it to run well all the time on the carb. 1st time I ran the EFi lump after a year out of a car it fired up and ran spot on.
Old 24th March 2010, 09:00 PM
dogwood's Avatar
dogwood dogwood is offline
Better beleive it....
Cheers Ash your a mate.
Did tell ya I don't do lektrix.....
I know the coil is OK coz getting a spark with the 1800 stuff.
I know the wiring is ok to the TFI thingy.
Coz I pulled it all apart and checked it with the digi.
So wondering if I bu*****d the black box.
David.
Old 24th March 2010, 09:04 PM
David.....
sorry mate but that statement has just had me in stitches
another long day, i,ll get my coat
glad you got the lecktrikery sorted
dogwood's Avatar
EFi is simple.
Simple for you. I've spent 2 days on the bloody thing.
Just don't make sense why there is no spark.
Got a spark first hit with the 1800 stuff.
It's just a poz/neg and the 3 wires to the Halls....done!!
With the injection,I just got a mass of wires with no idea where they all go, or what they do
David.
Old 24th March 2010, 09:06 PM
dogwood's Avatar
Well not sorted, but certainly closer.
Defo think I need to use the old KISS (Keep it simple stupid)
David.
Old 24th March 2010, 09:09 PM
snap, like i said previously....points & condensor & I had a chance with it,
anything else & i,m baffled with leccy stuff
looking forward to seeing your car "again" David
Old 24th March 2010, 09:14 PM
dogwood's Avatar
Me to......
Getting fed up with looking at a garage full of bits.
Not one of my better ideas to do a rebuild.
David.
