Old 23rd March 2010, 06:01 PM
dogwood's Avatar
dogwood dogwood is offline
Default Pinto EFI to carbs
After spending all day sosiging around with the EFI electrics
on my 2.0 Pinto, and not getting a spark, nore nuffin
I'm almost at the stage of giving up on it.
So question:
I have a Weber carb on a Pinto manifold, From my 1800.
Can I do a straight swop from the injection system to the Weber?
At least I know how to wire up the non injection system.
I havn't got time to go megajolt system,
So looking for a quick option....Stonleigh approching fast.
David.
Old 23rd March 2010, 07:01 PM
frankie boy's Avatar
Hi David
There is no problem with the carb. My pinto was a injection. You can put the dizzy from the 1.8 and run it standard.
There are some cheap twin 40 webers on ebay. Take a look.
my Roadster
Old 23rd March 2010, 07:06 PM
Has the pinto's engine loom been tampered with?
Old 23rd March 2010, 07:29 PM
dogwood's Avatar
Just a tad yes....
I cut and shut the wires to make them fit.
Think my joints are all good, but I just cant follow a wiring diagram.
Spent all day trying to get a spark.
Trouble is, there are just sooooooo many wires from the black box.
I'm going to try again tomorrow but if I have no luck then I got to look for an easy answer.
So my main question at the moment is.
Can I just unbolt the fuel injection system and bolt on the weber?
(It's a downdraught. forget which one at the mo,)
I realise I cant use the fuel pump. is there a place to bolt on the mech one?
I've had a sherbert or to so may not make much sense at the mo ....hic. ( Bad day, and fed up)
Arn't the dizzies the same 1800 and the 2.0...I've used the 1800 one coz it looked cleaner
David.
Old 23rd March 2010, 07:37 PM
Hi
You can put the pump from the 1.8 you will need the rod that pushes it. there is a blanking plate over the pump out-let.
my Roadster
Old 23rd March 2010, 07:42 PM
Originally Posted by dogwood View Post
Just a tad yes....
Im not shore But do you think you mite need the key to go with the ECU.
My dads old sierra did.
my Roadster
Old 23rd March 2010, 07:49 PM
dogwood's Avatar
????? key?????
David.
Old 23rd March 2010, 07:53 PM
????? key?????
The key would have had an immobiliser in it. You would need to tape it to the top of the ECU.
my Roadster
Old 23rd March 2010, 08:23 PM
dogwood's Avatar
Nope, no special key.
or anywere to tap anything in.
But thanks for the thought
David.
Old 23rd March 2010, 09:00 PM
HI Dave
I did mean the ignition key. The car would have come with two black keys and one red key. The black key had an immobilizer in the top. The red key was to reset it.
my Roadster
