Old 21st May 2013, 12:50 PM
vmax1974's Avatar
vmax1974 vmax1974 is offline
Default help i cant find what i am looking for
been doing some searching for some 14mm x 1mm wall seamless tube but everywhere i have tried comes up a resounding blank i have now spent 3 days on this can anyone help
i need for the botom of the rear hubs my only other option is a m14 bolt and i cant find them either
anyone got any advice
Old 21st May 2013, 01:01 PM
SteveMX5 SteveMX5 is offline
I got some from a supplier on eBay, can't remember who tho. I think it was called 14mm stainless precision tube.
Old 21st May 2013, 02:54 PM
If you type into ebay
Stainless Steel Tube 14mm OD x 300mm long 1mm w brushed.
it brings it up. you need 2 lengths.
seller is brilliant2buy
Old 21st May 2013, 03:26 PM
vmax1974's Avatar
Thanks gents
Old 21st May 2013, 04:10 PM
Beware using stainless and mild steel together,I think you guys mean seamless
any hydraulic supplier should be able to supply seamless pipe.
Old 22nd May 2013, 12:40 AM
PorkChop PorkChop is offline
No, they mean stainless. I would be worried about galvanic corrosion, especially as the lower rear upright to wishbone bolt (try saying that after a few tins too many ) is the worst bolt to undo anywhere on an MX-5. It's not uncommon for them needing to be cut off. On my donor, a 5' breaker bar with over 100kg of weight wasn't enough to even make them budge. I had to cut the bolts off with a hacksaw; reminds me, I still need to remove the centre part of the bolts from the upright...
Old 22nd May 2013, 08:31 AM
vmax1974's Avatar
Its mild that I have been looking for to avoid the corrosion but seems the right size of seamless mild is just not available may have to get some machineing done so many things annoying me about the build atm
All the engineering companies I try for an offcut of 5mm plate want to charge for the entire sheet when all I am after is half a square metre
Old 22nd May 2013, 11:13 AM
will_08 will_08 is offline
Its a pain when you don't have good access to materials.
I priced 5mm steel was something like 1/2M sq, was going to have a go at making the diff brackets and it was cheaper to buy them made from ebay!?!?!? wtf
Old 22nd May 2013, 01:03 PM
Buy some steel off ebay and give them the materials then you only need to pay for labour. My engine mounts were made with 5mm steel off ebay.
