Old 4th January 2014, 07:53 PM
Shorty Shorty is offline
Default upper harness mount position
Does anyone know how to line up the upper harness mounts in relation to the seat position?
I've seen the part of iva that states the minimum hight of the mounts but I'm also trying to figure out the width of the mounts.
I have the cross bar ready to drill and weld bushes in but just want to check on perfect position.
That's assuming my roll bar and seats are ok.
[IMG]http:// [/IMG]
[IMG]http:// [/IMG]
Old 5th January 2014, 09:45 AM
Not sure about positioning the mounts, but you might want to rethink the seats...
Harnesses don't really work when they go around the seats, ideally they need to go through them.
I found that when I had mine going around the outside of my seats the upper parts of the harness were constantly trying to slip off over my shoulders. If I leant forward I'd slip through them and headbutt the steering wheel - not much use in a crash
Old 5th January 2014, 04:33 PM
Oh bummer. I really liked those seats.
Old 5th January 2014, 05:04 PM
TSM Locost's Avatar
I have the same seats in my locost and no problems, as long as mountings are above your shoulder height, centres are 140mm from center line of seat. No idea for IVA as different seats used for SVA.
Be Lucky, Mike.
Old 5th January 2014, 05:05 PM
Sorry
They do look nice...
I seem to recall there is/was a kit available for lotus elise seats to add harness holes into them. Might be worth looking into?
EDIT: Just seen TSM's reply so I could be talking bollox!
Old 5th January 2014, 06:39 PM
Dont fit the cross bar untill you sort seats and bear in mind height requirement for IVA/seat belt.
Old 5th January 2014, 07:04 PM
There is an answer to this that might not be too popular but I'm going to say it any way,forget 4 point harnesses and fit inertia reel seat belts.
Reason 1: keep the same seats for IVA and post IVA
Reason 2: you sit at the end of a long bonnet in these cars and in 4 point harnesses you can't lean forward to look left past your passenger at junctions
Reason 3: have you ever taken a 7 into a pay at entry car park or at the toll booth and had to undo your 4 point belts?
Reason 4: one size fits all no need to adjust them for every body that gets in the passenger seat
I leave you to mull that little lot over before every body shoots me down in flames...
Old 5th January 2014, 07:29 PM
Reason 2: you sit at the end of a long bonnet in these cars and in 4 point harnesses you can't lean forward to look left past your passenger at junctions Reason 3: have you ever taken a 7 into a pay at entry car park or at the toll booth and had to undo your 4 point belts?
Reason 5: 0-60 time is about 5 minutes if you include the time to get into the harness...
Reason 6: ...or 10 minutes if you left your helmet/gloves in the passenger footwell and didn't realise until it was too late.
Reason 7: Adjusting your passenger wing mirror with your left foot whilst driving might be amusing but is probably neither safe nor legal!
Old 5th January 2014, 07:34 PM
Actually I like the sound of that.
I didn't realise that was possible as harnesses just seem to be the norm.
Do you have any info if I were to go that route?Parts needed and where would they be mounted
Old 5th January 2014, 07:35 PM
Isn't there a bit in 'the book' about it?
