Old 4th April 2014, 10:45 PM
onedayTM onedayTM is offline
Default clutch arm pivot pin
I seem to remember something about clutch pedal travel not being sufficient in zetec installations.GBS do an extended clutch pin for the black top . Do you need this with the silver top , mondeo clutch and extended release bearing? I dont have any clutch pin in my box so I need to get one which do I get and if it's the std one, can I still get one from Ford do you think.
tony
Old 5th April 2014, 07:15 PM
You will be lucky to get anything for a Type 9 from Ford,I wnated flywheel pins and they have been out of stock for years.
Old 7th April 2014, 11:01 AM
I believe the Black top and Silver top are identical WRT the clutch. I also have a 1.8 flywheel, Mondeo clutch and the longer CCT133 bearing. The clutch actuation point not far from the bottom of the pedal movement, but it works well as it is, pretty much.
Old 7th April 2014, 03:42 PM
1600 zetec f/wheel is lighter and aparently the better one to use.
Old 7th April 2014, 07:36 PM
cheers guys, so where do you think I could get pivot pin from then, Would the likes of Burton Power have one?
all suggestions welcome.
tony
Old 7th April 2014, 08:31 PM
You mean this? http://www.bearingkits.co.uk/Clutch-...ousing/625.htm
Old 7th April 2014, 09:57 PM
robj robj is offline
Burton power stock them. I need one as I put it in a safe place but can't remember where that was
Old 11th April 2014, 08:23 AM
snapper snapper is offline
GBS do an extended clutch arm pin than negates need for thicker release bearing
