Old 1st August 2014, 09:19 PM
Default Bike carbs arrived, supercharger on its way!
Having attended this year Dragstalgia event at Santa pod and seeing a Mk1 escort running a silvertop zetec with an M45 supercharger bolted on the side, I was inspired!
I will update my blog when I have started fabricating the intake, mounts etc.....
I got some throttle bodies off a late ZX10R with TPS. However I have now realised the ECU I was going to use (from chester sportscars) does not require a TPS and is really for bike carbs.
TBH I have little knowledge on ECUs, so some advice would be appreciated!
Old 1st August 2014, 09:31 PM
I should also add, I have the crank position sensor and flywheel already from the 2.0 zetec. So I would not require a timing gear etc...
Old 2nd August 2014, 09:12 PM
I hope your joking about the super charger, your boss will cut your you know what's off
Old 2nd August 2014, 09:16 PM
Haha, no pal, not joking it is on its way in the post!Will be awesome when its done, but give myself a whole load more to do!
Old 2nd August 2014, 11:05 PM
Then you had better order some incontenance pads then, adrenalin is brown
Old 4th August 2014, 10:35 AM
And runny....
Old 5th August 2014, 09:24 PM
haha thanks guys!
Looking around there seem to be plenty of ECU's. Megasquirt etc.... As long as its got fuel injectors and boost I think it should be ok. Just gotta figure out how it all wires up! But I am sure it will make sense when I get that far!
Old 5th August 2014, 09:25 PM
haha thanks guys!
Supercharger now arrived I will have a look at it 2moz!
Old 6th August 2014, 09:07 AM
they are paying you to much matey
Old 6th August 2014, 05:06 PM
I dont understand the need for the throttle bodies if its going to have a blower fitted. A standard manifold with a single throttle body would do the same job.
