Old 30th July 2015, 09:31 PM
Cropper Cropper is offline
Default MX5 Engine
Hi, finally got my project running, mx5 based, but I seem to be getting nice flames on overrun from the exhaust. It looks good in the garage but not ideal else where. Engine seems to rev cleanly & starts ok hot & cold, I presume I am getting a bit to much fuel through, any idea's
Neil
Old 31st July 2015, 08:05 AM
How much exhaust have you got connected while your running it, just the manifold or are they coming through the silencer and out the tail pipe?
Old 31st July 2015, 09:03 AM
the full system is on!
Old 31st July 2015, 11:00 PM
Mine does the same. I quite enjoy it
Old 1st August 2015, 08:16 AM
I take you had no problems with the IVA? I agree it does look good!
Old 1st August 2015, 08:19 AM
Not on emissions, no!
Old 3rd August 2015, 09:15 PM
Fixed it! Had to reset the throttle idle stop, it had been altered by previous owner of donor car. The throttle position sensor then had to be reset to suit the new idle stop. Before it must have been letting too much fuel through on idle hence the extra fuel getting through & causing the flames. It's now ticking over nicely & no more flames😃
Old 4th August 2015, 09:40 AM
If it has TPS on throttle body there is a micro switch in it that controls the fuel pump and should switch it off on "overrun"as you shut the throttle.
