Old 8th August 2009, 02:39 PM
doop doop is offline
Default gearbox identification
hi just woundering if any1 could help me ive got a 1992 sierra with 1.8cvh engine any1 know what type of gearbox is on it??
thanks
Old 8th August 2009, 02:52 PM
Almost certain it will be a type 9, 5 speed gearbox
Look at the bell housing. if it is not alloy, it will not be the MT75 box. As far as I know, they were only fitted to the 2 litre DOC sierras.
Old 8th August 2009, 03:00 PM
thanks for that just making sure so that i dont have to change transmission tunnel.
Old 8th August 2009, 07:56 PM
RAYLEE29's Avatar
RAYLEE29 RAYLEE29 is offline
Yup I agree its most prob a type 9 also another way of telling is where reverse gear is : left and forward type 9, right and back mt75, handy if you dont want to get under the car or bonnet just look at the gearknob
Ray
Old 9th August 2009, 05:05 PM
Hoybi's Avatar
Hoybi Hoybi is offline
Default Do as The Book says.
A trial fit of engine/gearbox is absolutely necessary. I had to change the transmission tunnel at the front end to accomodate the bulge in the bellhousing on the right and to give clearance for the clutch lever and still keep enough space at that side for my broad feet (LHD)
Eddy
www.alfaprojects.be
