Old 12th October 2009, 07:08 PM
dogwood's Avatar
dogwood dogwood is offline
Default 5bar alloy flooring?
After my last post about dodgy steel,
I have just been looking on Parker steel site.
I've got a question about alloy flooring.
I used 2mm 5251 alloy plate.
On Parkers steel they are showing 2mm 5bar tread 5754 alloy plate
Assuming the 5bar tread is raised up.
Does anyone know if this is 2mm plus the tread thickness
or 2mm including the tread?
Also what is the difference between 5251 and 5754?
Cheers David
Old 12th October 2009, 07:09 PM
Cheers David
Give me 5 mins, and I will pop out the back and measure the sheet I have
Done
2mm without the bar (ie on the flat bits)
Approx 3.2mm with the bars
So 2mm PLUS the tread
Hope that helps
Sean
Old 12th October 2009, 07:23 PM
dogwood's Avatar
Cheers Sean.
That's what I was hoping.
Old 12th October 2009, 07:51 PM
may i ask how you plan to get 8X4 sheets back to france?
Old 12th October 2009, 08:36 PM
dogwood's Avatar
Don't even start with me.........
Bloody Parkers gave me all that....
see my post dodgy steel....
Incase you wondered, this is how
I did it last time....
Old 12th October 2009, 08:47 PM
i see you and raise you this
Old 12th October 2009, 09:31 PM
David, I think the numbers refer to hardness ie 5000 is half hard (may be wrong )
Old 12th October 2009, 10:00 PM
Let me google that for you
http://tinyurl.com/yjz55k4
Second result - Roymech - a very very handy site for many engineering related questions, bolt sizes and pitches etc.
Sean
Old 12th October 2009, 10:17 PM
gingea1pom's Avatar
My offering
[IMG][/IMG]
Build Pictures
Old 12th October 2009, 10:26 PM
i didn,t take a photo but i,ve recently had over 200mtrs of box erw steel inside my van , picked up in batches, cut into 3mtrs lengths carrying 40 lengths a time & its all for Roadster builds
i,ll take the camera next time
