Old 18th November 2009, 07:30 PM
car.mad car.mad is offline
Default Zetec 2.0
hi
has anyone had any experiance using this engine?
thinking of using a Ford 2.0 Zetec engine for my car but im not sure what i need to do for it...
i would idealy like the car ECU Driven (because i want to do auto electronics at uni and it makes me learn)
anyone have any idea of what this would consist of? i know i need...
Engine
Gearbox (Sierra - Same bolt pattern)
Alternator
Starter Motor
Manifolds (will make own exhaust manifold)
injectors
ECU
Wiring harness
Cant think of anything else but im sure there will be somthing
Jake
If in doubt... Give it a clout!
My Build Thread - http://www.haynes.co.uk/forums/showthread.php?t=2995
Build Pics http://s804.photobucket.com/albums/yy326/jake_hornsby/
Spent So Far - £90
Old 18th November 2009, 07:48 PM
I too am thinking of going the 2.0 zetec route.
Allegedly, the 1.8 flywheel is a lot lighter.
Which Sierra box are you using? I have an MT75 that I will be fitting. This requires some jiggery pokery with the clutch release bearing (it needs a spacer).
There is quite a bit of info on the net.
Sean
Old 18th November 2009, 07:51 PM
Aha, knew I had it somewhere.
Hope the attached file is of some help
Covers mating a zetec to both Type 9 and MT75 boxes.
Sean
Old 18th November 2009, 08:01 PM
Not sure on the box yet will be going to scrap yards and demonsterating some sierras for bits... apparently theres a good scrap yard in york called 'u pull it' who will let you strip what you want off a car. a friend of mine got a gearbox for his aincient VW polo for £25 or somthing along thise lines
Jake
Spent So Far - £90
Old 18th November 2009, 08:06 PM
I got my MT75 box for £50 off a guy on another forum.
Sean
Old 18th November 2009, 08:13 PM
If your going down the Zetec, its not a million miles away from what I've done. But you'll run into a few problems. Which 2ltr model are you going for?
First off your sump needs some substantial modifying to make it suitable for the ground clearance and RWD use.
Your thermostat and water rail needs modifying or its going to impact on the bulkhead.
The alternator off the donor engine will be fine, but you'll need to make new mounts and probably replace the belt as you'll want to ditch everything off the ancillary belt (PAS, ABS, Aircon etc).
Starter motor should be compatible for your bellhousing. So whatever the gearbox originally came off. Mine is off a 1.8cvh for a Type 9. You'll prolly want a starter off a DOHC if your using a MT75.
ECU, Well I assume your going fuel injection? Sticking with the original manifolds and throttle body? So grab the loom off a pre-pats engine and it will fire up straight away. Thats it. Super easy.
Now how old is your engine going to be? Because you'll need to consider emissions if its after '94. So you'll also need all the catalytic converter guff.
Old 18th November 2009, 08:48 PM
not a clue what year engine or which one at the moment only just started the chassis but im just wanting to know if it will work really
will save all the stuff people say in a word doc or somthing
really useful info
Jake
Spent So Far - £90
Old 18th November 2009, 10:54 PM
frankie boy's Avatar
HI
I’m building a new car with the 20liter zetec from a mondao. The sump is not so much of a problem. I’m going down the plug and play rout with the engine with type nine gear box. I have move a some bits in the chassis but only to save some money.
As I have a roadster with now 5000 miles on the clock I now what I wont from my new build and cheap its not. The silver top from the mondao is 136 bhp out of the box. With the throttle bodies and ECU 165 bhp is easy. That’s 300 bhp per tone that will keep me happy on the local roads and track.
my Roadster
Old 18th November 2009, 11:18 PM
It's an easy choice:
donor cvh for easy IVA then it's a pretty easy exchange for a 2.0l Zetec. Throttle bodies are expensive but the engine purrs like a pussy on bike carbs and megajolt. Get the carbs setup professionally though.
Puts a smile on my face without fail......
Old 19th November 2009, 08:29 AM
Get a Megasquirt kit from diyautotune.com and solder it up yourself! Carbs are so XX century.
Apparently on LHD the original plastic intake manifold from a Focus (Zetec black top) fits in, the throttle body sits more or less flush with the top of the engine. On RHD it seems to interfere with the steering column. Also the black-top sump is easier to modify as it has a detachable steel bottom that can be shortened and welded.
That's my plan anyway -- make a well-behaved, environmentally friendly, catalysed Zetec-E stage 3 setup for registration, then convert to ITBs if I want to tinker for more power.
